How to debadge
Hi guys,i would debadge the wagon in the rear,cause i've to fix some rust and want to paint the rear panel...i've tried to take off the H emblem but didn't want to come off;i wouldn't to break it>how could i remove it? :roll:
String it under a few times... pull.
Slip it under the edge of the badge then use in a gentle sawing motion to "cut" through the adhesive. Keep in mind there will be some plastic locating tabs you wont be able to cut through so need to come in from a couple of angles
assuming the tabs are still there are it wasn't just glued/taped on at some point.
if you have a heat gun, use it for a couple of minutes first. will help loosen up the adhesive.
