hmmm, were they carrying it by the pickup? i think you could make it work, the oil thing, i don't think so on that... did they run it dry and thats how you got it?
when it broke did the pieces end up in the bearings, oil pump, or any thing else in the eng while it was running?
i'm sure some one else will chime in that has alot more knowledge.
I haven't found the all the pieces yet. Seems to be some gold flakes on the oil pan. Block Coolant plug looked bad but the system otherwise looks clean.
Nope I just picked this up to try and see if I could replace my A6. It was cheap. Crank dosent even turn. I could try a mini-me but the idea was to keep the car in service as long as possible before putting it in for the new heart. I wonder if a machinist could fix this.
Thanks just wondering because I can't slide my smallest feeler gauge in any but the fourth rod end. I know there is supposed to be at least some play but not too much. Maybe that's why it's locked up. My second guess is the pistons so I put some kroil and sea foam sitting in the cylinders overnight.
Some of the worst ring ridge is on number 1. I used some emory cloth to get most the carbon off. I heard it wasn't really a good idea to use a ridge reamer tool. I didn't feel comfortable using one anyhow.
bowz
but if the crank isnt turning you got bigger problems.
Thanks for your encouragement
"4. reinstall the bearing cap, then torque the bolt.
1st step : 25N m 18ft lb
Final Step:
Final Step:
D16Z6 58N m...38 ft lbs
Except D16Z6: 45 N m...33ft lbs"
tq down the bolts in two steps, first step to 18ftlb, and for a D16z6 the 2nd step is 38ftlb.
