It goes bang bang bang everytime i hit a bump or pothole wtf
ok so i have a 90 wagovan slammed on skunk2 coilovers and everytime i hit a bump or pothole it goes bang bang bang i know my shocks up fron are bad is that the onlhy problem or is there more...please help
  • nwWagoRTnwWagoRT New Wagonist
    I'm guessing your struts are bottoming out. How slammed are you?
  • NZ-DB8RNZ-DB8R Moderator
    Im guessing your springs arnt captive either. aka dodgy as hell.
    Also please read the rules, I know you havnt
  • jimmyJonjimmyJon Band Wagon
    u might be hitting ur upper control car on ur fender well like i do...
  • punx45punx45 Band Wagon
    Um... ??? Care to clarify the problem here?
    back on topic.. strut mounts?
    Don't hit potholes or bumps lol
  • jloehleinjloehlein Band Wagon
    It's likely not this on your car, but while you're looking at other things check out the sway bar bushings and end links. I've had a car where it sounded like something was hitting the floorpan, only further forward, over bumps. I went under there and the sway bar bushings were noticeably worn. You couldn't yet move it around by hand, but replacing the bushings solved the issue. I've also seen a car where the sway bar to subframe mounting bracket bolts were torn out, causing it to whack the subframe all the time.
  • jasnalljasnall Wagonist
    what kind of bang are you talking about? It would help to have a better discription. Does the car continue to bounce as its banging? Or does it still bang when he car is not bouncing? Is it more of a rattle? Could be struts, or just the springs doing nothing.
    Wait you said you're on coilovers? are they old? just the front shocks or blown? is that where the bang is?
