Clutch issue.help!
before my clutch bracket broke common on rt wagons.there has been an issue with my clutch.car would be hard to go in gear and everytime i press on the clutch the pedal wouldnt come back up.some are telling me its the push rod bearing.some are telling me its the cable clutch.idk and am in need of help
there listed but haven't been available in years. you will just get a refund. trust me, i tried to purchase one. used or repair are your options.
here is a link to my pedal bracket viewtopic.php?f=7&t=10656
you can see the gusset my friend added. should never brake again.
good luck to you. its a pita but very gratifying once you take it out for a test drive.
