Edm/jdm rear tail lights
just installed mine.
i noticed that the corner lamp doesn't have a parking light. is it okay not to have the corner light on.
if so, can i connect it to the rear tail light as a constant w/o melting the plastic?
i just don't want to deal with the law out here.
thanks.
thanks.
When the park lights are on the tail light should be on, when you brake then the brake light activates.
The rear doesnt have a separate "park light"
thats what I did
thats what i did already.
i was just wonder if i could wire up the turn signal with the parking light without melting the housing?
like a side marker constantly on, but flashes when turn signals activate.
if you think the law is going to interfere, well, then you better go back to USDM
this is an absurdly horrid idea, and very much illegal.
