been debating about getting one. Any pros and Cons from people that have them i would like to know im thinking it would help tuck my intercooler in some more but thats just me?
Yes, there is much more room with the EF9 cover AND* radiator support. You will have much better luck tucking an IC in there...
The bumper bows outward 4-5 inches, while the wagon one is pretty much square-nosed. hard to explain...
It does take a bit of fudging to get the bumper and filler to work properly.....
2x's. I second this. Definately more room in the EF9 bumper if you plan to run an intercooler and the grill is obviously bigger than wagon bumper grill so it will breath better.
The EF9 bumper needs tweaking to make it fit the wagon. For instance. You have to use the wagon filler piece on the EF9 bumper. I had to notch 2 small pieces off the EF9 bumper support so the bumper will go in more. Take sum finessing to get it right but it can be done. Patience is key.
All that extra work and patience pays off, looks great.
I don't like them, they don't suit the Wagon, have different trim/moulding...
An EF9 bumper is made for an EF9, not a Wagon.
So pro's..... you get MAD JDM points from your boys
Con's.... it looks whack
the EF9 has the most room.....
But you can fill the EF9 bumper's trim and it can match the wagon's trims.
Here's wat we did to ours to match the wagons trims.
EF9 bumper with the trim filled. I think it compliments the wagons trims well now. 8)
o the usdm support will work- you just have to rape and pilage it...
ARRGHHH!
shiver-me-timbersssssss.....
Really easy to fit, takes about 10mins to mod it with a drill and a sharp knife
