Help Help Help Dpfi to Mpfi
K so i swapped in a d16a6 on my civic it formally had the d15blah blah.Anyway according to all the diagrams on this site I should have 2 open pins on 10 and 12,Well i don't i have 2 open pins on 11 and 12 so i ran the crank trigger and tdc sensor to those two.Car starts idles and everything but I have a code 4 and 20 .Crank trigger angle and power loss.Also car will not rev past 3500 RPM.What gives?Any ideas or suggestions?
    double check, then triple check your wiring. i had the same issue when i did my MPFI swap, and it took me a month of frustration and agony to finally notice i had two wires backwards :x
    check this link out, its what i used...
    http://fourthgenhatch.net/mpfi.html
  • Thanks for the link,It is alot more detailed than what I was using as a reference. :D
  • So turns out I had all the wiring correct,so i decided to swap in an old core distributor that I had kicking around.Turns out my new distributor was NFG.WTF is all I have to say.Almost a full day of headache due to a defective part.Somebody is gonna get a hurt real good.
  • danzdanz Wagonist
    NEW to you? or completely new? what brand?
  • It was a brand new Beck Arnley
  • danzdanz Wagonist
    lordco strikes again.
    ive had really good luck with Ultra-8 brand distributors, which are available at napa and lordco for a little more $
  • JakerJaker familEE
    I'm giving up altogether on Honda distributors and ignitors. Here's my new ignition setup:
    http://www.hondata.com/hondata_coil_pack_retrofit.html
