So I know you guys are tired of hearing this... BUT!
                    I have found some other choices, and I can't decided on what the best thing to do is.
Right now I have a D15, Auto, she smokes on anything over 4,000 RPMs, uses a little oil..
I want a new motor, but this car is a daily driver and I don't think I can afford a lot of downtime. I just want some more power out of this thing, I'm not really all that concerned with racing and what not. I want to be able to have enough power to zoom outa the way, and this thing isn't cutting it.
So here are the options.
Turbo the D15, maybe freshen it up a little. Almost no downtime, bolt on.
JDM ZC, probably a couple days downtime, cheap, could produce pretty good power, but a turbo D15 would blow it away.
B-Series, about a week downtime, wiring, mounts, etc. etc. Could outrun a ZC, give a turbo D15 a run for it's money.
H-Series, Who am I kidding, I can't afford to put a H in my car, or the downtime.
So there's my options, I'm really leaning towards the Turbo, it would be cheap, effective, and have enough power to suit me, and I would have a Hella cool front mount!!
Opinions?
Opinions?
IMO go with either a DOHC ZC, and maybe even eventually boost that OR just boost your D15, but like you said it would need a little freshening
motors are cheap, cheap, cheap - with tons of potential. 140 lb-ft stock, 1st gen DSM turbo manifold bolts on with minor mods, and did i mention they're cheap?
I have no experience on it, and I think I could swap in a ZC since I've been reading a lot with it.
But a turbo will cost around the same and have tons more power, and it's practically bolt on.
I don't know.
yes you'll put up higher HP gains with the turbo, but you'll spend more money on it in the long run due to keeping it running in tip-top shape. plus i've always been a fan of the ZC. its a practical engine to swap into the wagon, and the numbers arent over impressive, but its a nice engine with some spunk to it.
B series if you can spring about $1300 to 1500..which is not bad considering.
you can even keep it auto if you want..there's an auto B series..nobody tends to buy those so the price isn't very high.
the 1st gens put out 160hp..you may get 140 or so to the wheels. the 2nd gens 170hp..
i'm not sure but you might even be able to add on LSD to it.
if you don't have harsh smog laws, i say go with the most power. CA people have to keep that on the DL.
or a h/f-to-d and keep the rt4wd :twisted:
