$%&$*@ Drivers Side CV shaft won't seat fully
So I did a search and couldn't find anything on this.
I'm putting my car back together since I finally got the right trans, and I can't get the drivers side axle to fully seat into that extension that comes off the trans. It goes in about 4/5ths of the way, and then no amount of tapping will get it any further. It's clean, I sprayed some GM superlube on the thing (both axle and the "half shaft") and it won't budge. I can pull it back out easy after a couple taps with a pry bar. Yes, it's the same axle that came out of that side when I took it apart.
Any tricks to getting this thing back in there all the way?
Someone on the interwebs already had a pic!
