DIY clear corners under $30
so the lens on my SiR corner fell off. compering it over the wagon corner notice it was bigger, so dicided to order some ebay clear corners to take the lens off and over lay on some broken wagon corners I had laying around. But it turned out to be imposible and decided to just trim the CRX corners and this is what I got you will need a heat gun to heat and bend crx corners to fit better
I used a 4" grinder with cutting wheel to trim the corners
I used paper to trace patern and transfer it to the CRX corner
I see the pix. I can read the instructions. I don't see the issue...???
This.......
