Ignition timing
so i just did the MPFI swap and i need to set the ignition timing. so heres the question do I
- set the ignition timing to the dpfi which is 12 degrees BTDC
-or set the ignition timing to the MPFI which is ( ????? i cant find info on that )
any help would be great thanks
96-00's go to 12 degrees, which is the middle mark as well on their crank pulleys. that would be OBD2 cars, Y7s, Y8s, etc
if you are using your stock ECU, or an OBD0 or OBD1 ECU, set your timing to 16 degrees.
if you dont have the marks on your crank pulley, i would go ahead and buy a digital timing light so you can set it to 16 degrees on the light itself, and use the TDC mark on the crank pulley.
if u NEED to use a different crank pulley, use one off of a D16. it is a harmonic dampener, where the D15 pulley is solid.
you want the dampener to help with the terrible RS ratio of the D16+
im running a pm6 ecu kept the car obd0 just purchased a digital timing light it will be here soon i will keep u posted on the info
Not to mention install a new waterpump, and tensioner....
