Slight grinding when going straight, fine when turning?!
Just like it says...
My wagon is at 129,xxx miles, and has just started this noise. From the front end, and most likely the front drivers side. At first i thought it was because i had some blizzaks fitted, but it has started to get a bit louder with each thousand miles. I have just noticed that if i turn to the right, the noise is not really noticeable, but is the same if i turn left.
I have checked all dust covers, pads and calipers, and no, it's not rubbing on anything.
My only guess is the wheel berings are shot? or atleast the left wheel, but id replace both just to be safe...
All other suspension pieces are tight and sound.
anyone else have any suggestions?
Usually wheel bearings make noise when TURNING, not going straight....
hmmm.
im stumped.
hmmm.
im stumped.
it's a mystery!
