Main Relay or Fuel Pump
My RT doesn't want to turn over when I refuel. So I sit and crank it for what seems like forever at the pump...
Noticed the guy before me had the fuel filter hooked up in the reverse order....changed it, didn't help the refueling issue.
At first, I'm thinking the fuel pump is bad, because I read 12 volts at the fuel pump...dismissing the fact that maybe I should test the resistance on the main relay, because it works intermittently, and I don't hear the fuel pump making bad noises (unless of course the leads came loose on the pump motor itself after the connector).
I think the previous owner sold the car because he couldn't figure out why it does this...he replaced the whole distributor, plugs, wires, the whole 9 yards...
Think it's the fuel pump or main relay?
If it is original you should replace it anyways, even if it turns out NOT to be the solution to your current issue. Or, if you have the skills, at least take it out and inspect the solder joints and resolder if necessary.
Each time I hooked it up to the battery, i could hear it making contact, all sounded the same, no weak click for either combinations.
Because this happens at each fill up, my friend, sea-doo tech for R&D and former race team tech, suggests vapor lock.
Thinking about inspecting the pump, and the in tank filter guy...it's been in the snow belt sucking e-85 crap for god knows how long...238,000 miles as well....
The screen looked brand new as well.
Maybe this is why he sold it, dumped money into parts and never fixed the problem.
The_Head: if the solder joints look kosher, think something internal has fouled?
Any other thoughts?
BATTERY voltage (same exact as battery) indicates an OPEN. Slightly less, close to source or varying voltage across the pump means the fuel pump is consuming the voltage but not doing its job
