Alternator makin noise help plz?
Hi guys, so my alternator is making noise when it starts but still charges just fine.
I'm just guessing the bearings in it just worn out, and I'm just wondering is there a way to stop it, and if i do have to change it, is there a easy way to get it out or do i have to take out the intake manifold. [d15b2 mpi]
Sure it isnt the belt is loose/worn?
If it is the bearings it is super easy to remove, can do it with a couple spanners (remember to disconnect the battery first)
if i do have to take it out do i have to remove the intake manifold to get to it? its on a d15b2 with a dpi. thx
Its not the shocks you have to worry about, if you short it out then chances are you will weld your spanner/tool to something or loose a big chunk of it.
The service manual says to remove it from under the car. First remove the alternator from the bracket, then remove the bracket from the engine block. Only then will you have enough clearance to drop the alternator down between the rear crossmember and the block. It is not at all difficult - takes me about 30 minutes start to finish. BOBBOY's method might be slightly more work???, but you don't have to be underneath the car.
