right/rear brake pulsing/grabbing & releasing.
urgent help. i tried sifting through the crap on honda-tech.com's search archives and ours but came up with no answers. it makes me very glad that i don't have to go there very often thanks to this board.
the reason for the urgent help, i use my car for deliveries/work. 412,000kms and the faith to use for deliveries? you bet. anyway...
when i apply brakes the right rear makes a very distinguishable clunking/grabbing & releasing. you can feel the car squat and lift, squat and lift in that corner at very low speeds. only when brakes are applied.
new pads were installed about 2300kms ago.
a. warped drum?
b. not adjusted pads, to much gap?
c. debris?
i'll check b. & c. tomorrow. any other ideas?
a. warped drum?
c. debris?
make sure the shoes are on right.
when i did my swap a year ago i had the same problem. found out it was a warped rotor and then the caliper wasn't functioning right..i had to replace the whole caliper + new rotors.
now the noise still exists, a bit quieter, not much. and now in reverse the brake wants to lock up, but only in reverse and only after about a half rotation of the wheel. only sometimes. very strange indeed. i think i need a brake shop. i hate drum brakes with a passion that many can relate with.
That is precisely why I'm thinking of doing the drum to disc conversion next summer.
Good luck with your brakes !!
