Better Gas Mileage on RT4wd
What are so suggestions for better gas mileage.
I used to own a 2001 civic which lasted me double the mileage!
What are some suggestions?
I think since its Multi point and not duel injected. It wastes more fuel??
You think its possible if i can get Individual Injection?
Sorry if I Didn't search it up, it's really hard searching for this subject.
1)Switching off the rear drive & changing the rear diff. fluid to the newer lower weight synthetic stuff.
2)Putting dubs on.
3)Swapping a Vtec head on.
4)Civic 2WD tranny swap
Wrd.
On top of that you may wanna consider
1. Lighter wheels(this makes a big difference).
2. Doing a full tune-up. Fresh cap/rotor/wires make a HUGE difference.
3. Adjust timing..make sure its perfect.
4. Tire pressure.
5. Lower your car and get a good lip spoiler.
6. Shed excess weight from the car.
7. Read up on hypermiling.
The only way to get high 30's is with a DX 2WD tranny.
A HF tranny will bump it to mid to high 40's.link to more tranny info
try not driving around with a full tank of gas all the time the extra weight kills the gas mileage with all the going and stopping . i usually drive with only a quarter tank in my car at any given time unless im doing a long highway drive which means that i gas up at the gas station closest to the on-ramp of the highway im going on.
these tips added to what was said above should work
REally? how did you get it so high?
i always get 180mpg on a full tank it sucks, with this economy
With the Rt, they are just heavy, so it is a losing battle... And, they have horrible aero-dynamics.
My 89 Dx hatch gets over 40 with the air on.. I am thinking about doing some aero mods too, just to see what it does..
Taller tires helps on the highway, but kills your around town & take offs..
Drive barefooted on your throttle.. This actually works and was a tip I got off of a hyper-mileage website... You realized that you are less heavy footed when you do so.
