And I gotta do a better measure on height. But dam ur real low. Wht have u done to clear the a arms. I still hit on mine
I've actually done nothing for the control arms. I'm not sure why I don't hit but as far as I know they don't. You measured to the top of the door by the rear corner?
I went to top of roof cause my door sages. I figure it was an easy way
Need a re measure gotta see how low u are I changed where to measure
I will as soon as I can. My car is stored in a different city than I live in. The other day was actually the first time I had laid eyes on my car in three months.
I like to take measures from the ground to the tip of the fender that way you get a front and rear measurement. Good way to compare stance. Unless you have rolled fenders I guess.
Ya thought about different places to measure but the door is a similar on our wagons
Ok so I HAD measure my car, lol, I couldn't stand it.
So here is the stats.
I'm bottom of the handle..... 26 7/8's
That's achieved by cut springs front springs 3 1/2" and 5 1/2" out of the rears
Setting on fat fives wrapped in 195/45 (or 50's)
that is as low as I can go without putting extended top hats on, it would bottom out bad.
I just measured my boyfriends's '91 RT4WD and it is 30 7/8" to the bottom of the door handle. Mine is still at the mechanic's. It has broken front springs, so I know it is lower.
Did you mean 68 cm? 68mm is 2 11/16".
what size tires are you running, im on 195-45-16 cause that might make a difference on measurements also.
drum roll........................ 26 1/2''
I am shopping around for 195/45/15s right now which will help. I have 14'' balloon tires on right now.
its on air cylinders, but i ended up removing them and ordering seals.
i'd like to know this...
mine is....33 1/4"
i think i might be higher than everybody haha
LOL thanks!
