Motor mounts for RT4WD ?
I need to get motor mounts for RT4WD auto but someone said it is different with one that is used on manual model. viewtopic.php?f=5&t=10077 So, I tried to find them on eBay but I couldn't find right one for automatic.
Where can I get these mounts for auto RT4WD? What brand should I get? I have a stock motor D16.
Thanks
Thanks
Thanks
im not a wagon genious yet, but ive never heard of oil fluid being used in motor mounts. its eurathane, now cheap mounts probably use a cheaply made eurethane that will probably rip and tear sooner due to bad chemistry in making the eurethane. i would stick with innovative, OEM or Energy. im not sure if energy makes them for the wagon. Like someone else already stated i would try the junk yard first, then price out oem and aftermarket... and personally i would do them all at the same time but if $ is an issue i would do the front and rear then the sides(front and rear control more of the torque from ur motor)unless one of the side's eurethane is just completely blown out...
