Need Info On Stock Coil Springs ?
Alright im looking to lift my wagon and i have read that you can raise it with accord springs and da springs also.
I work at a parts store and i can look up coil springs by inside dia., load, free height etc.
So im thinking of doing some testing on my wagon to see how big of a coil i can fit in it.
What im really looking for is specs on stock coil springs off of these wagons?
I dont have my old ones off and didnt plan on taking them off till summer time, since this is my project.
Specs i need:
Inside Dia.
Free Height
and possible pics of the top and bottom of the coil cause i have to identify if there, square end, tangential end or pigtail end
any info would be awesome thanks
    byrne_06 wrote:
    I work at a parts store and i can look up coil springs by inside dia., load, free height etc. What im really looking for is specs on stock coil springs off of these wagons?
    :? I'm confused.If you can look it up.Why can't you lookup the Wgn.specs?...or just look up CRX specs.Please do a search.There are pics of the OEM springs on this site.Go outside & look under your Wgn. to see what the ends are.
  • byrne_06byrne_06 New Wagonist
    are they the same wagon to crx to hatch ? cause my book wont look up a wagon
    The book has no listing for any ef coil springs so this is why i need help thanks
  • inceptioninception New Wagonist
    just use a stiff coil over like skunk2 and u should be fine...Just dont use a soft spring cause the wagon weighs a lot more than crx or civic.....Not sure about the accord springs,but u can lift it pretty high with coil overs.Make a trip to the junkyard for a test set of springs from an accord....
    All 88-91 Civics springs are all in the same ballpark for your purpose.Since you know DA springs will work.Use that as your starting point for all your specs.
