Cracked manifold repair question.
Couldn't pass SMOG. The tech said he thought it was an exhaust issue. I checked everything along the bottom of the car, but couldn't find anything. So I took off the heat shield on the manifold, and guess what I found, a cracked manifold. I need a quick fix for the SMOG. Is there away to fix instead of replacing?
my other car is a 1974 saab 99 ems, and repeated welding on the manifold over 20 years made it impossible to weld. but they were doing weird stuff like using it as an engine mount of all things. I ended up making a custom manifold out of a bunch of schedule 40 elbows.
