Throttle position sensor troubles PLEASE HELP
Hey gang,
My 1988 stock civic wagovan is grounded in my driveway for want of a new throttle position sensor. I ordered one from an online retailer that claimed to be a direct swap for my car exactly only when it showed up it was a mirror image of what i actually needed.
just to help further clarify what I am asking for.
I have attached an image of the parts in question
in the image you will see Dorman part number 911-753 which I received
as a "direct replacement" for the part on the right which I pulled off
of my throttle body.
Because the parts are mirror image, the following is not working:
both of these parts rest in the closed or off position by default. My
part rotates clockwise from the 10 to 2 oclock position as viewed
from the inside of the throttle position sensor. Dorman part number
911-753 rotates counter clockwise from the 2 oclock to 10 oclock
position. This if installed on my car. the actuator in my throttle
body will push the rotating part of the TPS into its own stop.
Does Dorman or anyone else manufacture a mirror image part like mine? somebody please help!
