Shaking
well, i pu in new tie rod end to where it was loose. i got newrack and pinion. bearings are fine, and everytime i lower my car it still shakes turnin right. anyone maybe knows whats wrong?
  • oh yah, and when i go straight it will go away. and when i hit like a poth hole it will do a lil shaking then gone.
  • ppruepprue Wagonist
    I'm getting the same thing, new brakes and rotors, good alignment, fairly tight front end. When i ease into a a curve at a decent speed say 40 mph or more i feel a shake also, seems more noticeable when going to the right. In the straight smooth as glass.
  • im starting to think its the inner tie rods for right wheel.
  • cv axles__
  • so shud i just replace the whole axle?
  • Since you said it only does it when turning, it made me think of a bad cv joint.
    Have you jacked the car up and tried to wiggle the wheels to check for play in the suspension?
  • the left wheel had play and it was the outer tie rod. the right has play to bu its not the tie rod this time. but it wiggles left and right. the left wheel is good as new.
    checked your radius rod bushings? the ones that go through the front sub-frame from the lower control arms. if you haven't replaced them, do, it's an easy job. huge difference if old ones are worn.
  • can you show me a pic?
