Can anyone help or maybe its just the relay for the signal lights...but they still light up but do not relay to blink....so manual signaling is a must for now...please help thanks
do all your bulbs work? if a bulb goes out the lights do not blink correctly.
if they all work then its most likely the relay (which is simply plugged into the under-dash fuse box)
