Mini me swap plus other crap
so. finally i went ahead and did my mpfi/mini me.
a friend and i converted the car to mpfi
also i took the stock jdm single zc head off. and threw on my fav d16y8 head with manifold and fuel rail.
a6 diz
jdm b16 injectors
accord resistor box
y8 honda oem metal head gasket
new honda oem timing belt (y8 because its three teeth shorter to make up for the y8/zc head height difference) i set the timing one whole tooth advanced so its technically .5 tooth advanced because of the half tooth retard that comes with the y8 head. runs amazing.
ac belt removal lol.
started first try no problem. the power difference was major. im getting a tps and iat sensor code. idk why the tps but the iat of course cant be mounted on the y8 mani, surely causing a code. other than that it runs great. been driving it for a few weeks now. of course im still obd0 so no vtec:( but i just got my jumper harness in the mail today so that will change by tomorrow. also some dc headers were used.
compression is 175 all the way across
going to use a p28 ecu
planning to purchase a cam and tune.
also installed a ls integra shifter made quite a diff
the pictures are of the whole y8 with a spun rod in my wagon being transported to the garage
the zc head off and some coolant in the cylinders
the motor in and running with mpfi
oh yeah, fit rims too. i think i might get fit badges maybe. idk.
a6 diz
jdm b16 injectors
accord resistor box
And for an update I am now obd1 vtec with the p28.
Still running obd0 injectors though. I meant to ask is there any flow difference at all with obd1? Saturated and unsaturated and whatnot.
