Only way to remove LCA = sawzall?
So the story is that I have 2 degrees excess positive camber on my front pass side wheel due to previous owner. I replaced the knuckle since it had a bad wheel bearing. This didn't fix the camber. So I'm thinking it has to be the LCA. Unfortunately all the LCAs I've tried to pull from the junkyard have the same problem. The inner bolt is fused to the sleeve, so the bushing rips and spins freely making it impossible to remove. The only thing I can think of is to cut the bolt in two places with a sawzall (that I don't have).
It's virtually impossible to get an impact in there and I fear that it wouldn't help anyway.
Does anyone have a better suggestion? Do I need to swap the entire subframe with the LCAs?
Possibly a bent radius rod?
For a VERY experienced metalworker, yes.
Thanks for everyone's responses! I can't believe they're only $56 at Rock Auto!
