I got problems.
My AUTO RT4WD tranny grinds in reverse. What do i need to do to fix it?
I have oil in my first 2 spark wholes starting from the left. Are my valve cover gasket where the spark wholes are broke or bad?
my car overheats bad. How do i find out whats wrong?
im working on my car now so if you know the answers for sure. lmk asap 17275511898 text would ne great thanks
WHERE DOES MY THERMOSTAT GO????
-Oil in spark plug holes, yes the gaskets in the rocker cover are perished, order some new ones
-Overheating, replace thermostat, flush out radiator, make sure fan is working
tranny still griend after puttin more tranny fulid in it. it will also slip out of gear when making a right turn. anything out << thant one?
- will got new valve cover gasket tomorrow and replace sparks and plugs
- brand new radiator with only 50/50 cooolant from advanced auto. fans do work and i have a thermostate whice i will replace tomorrow also.
keeep everyone updated with it.
thanks
thankis there 33 buck for the whoole thing includiong garment and spark plug tube gasket
