Noisy RT4WD : Transmission ?
My Shuttle is very noisy on the road.
The noise is like the noise from the reverse gear (but lower).
The noise appear only when the wheels are spinnig, it still there when I press the clutch pedal (while the car roll).
I thought it was the Tires, I tried with my 2 sets of wheels : No change.
I changed the oil, MTF3, two times : No change.
The gear changing is very smooth, all the synchros are OK
The 2 front bearings are brandnew.
Please help anyone ?
Thank you very much !!!!
You mean transmission Bearing(s) or wheel Bearing(s) ?
Is the noise coming from the front or the rear of the Shuttle?
shifts perfect just feels like its dragging a bit.
pissed !!!
one guy quoted crazy $$$ for a rebuilt. i've got it being taken apart by this guy to see what the problem is and what needs to be done and said he could get a used one for $450 if need be. ???
I'm not enough confident for rebuild the my trans
