Seat belt chime disable? Help.
I've search and can't quite find what I need. I re-wired my speakers in my passenger side door and my passenger side auto seat belt doesn't retract anymore. I've tried the fuses on the battery, and the wiring harness on the belt retractor on the seat...nothing. My driver side still works, but when I close my passenger side door the belt warning light blinks and the beeping starts.
I just need to disable the chime until I can get it fixed. Does anyone know of a way to turn it off or unhook it? Or even better a possible solution for my seat belt woes? Thanks guys.
  • JakerJaker familEE
    If memory serves me right, you can unplug the wiring under the passenger seat, and make a small jumper wire to close the "switch" that the system is looking for. I'll check the wire colors when I get home.
