Need Help With A Head Gasket Parts List
Hi I need to do a head gasket on a friend of mines D16 nonvtec and I was trying to come up with a part list for her, i don't necessarily need prices (would always help if you have them
) but what should I do while I do the head gasket.
I need...
- Head Gasket (How much are those)
- Oil
- Coolant
- Thermostat
- Exhaust manifold gasket ?
- Intake manifold gasket ?
- Distributor O-Ring (Do I need to remove the distributor)
and that is pretty much all i know i need to change
Or if you have a link that tells me what I need ill look at it. Usually I would try and research myself but I am really pressed for time can my Honda Wagon Owners come to my rescue lol
Thanks everyone in advance.
I need...
- Oil
- Coolant
- Thermostat
http://cgi.ebay.com/ebaymotors/92-95-1- ... 53e0a7f283
and this
http://cgi.ebay.com/ebaymotors/96-97-1- ... 3ca4e3eba6
However, if you're on a budget, you can just buy the head gasket and remove the head with manifolds attached.
More importantly, how old is the timing belt? Here's what I would do if I were on a tight budget:
Head gasket $35ish
Timing belt $40ish
water pump $30ish
Thermostat $15?
Oil, filter, coolant $25
hondata intake manifold gasket, reusable. lowers your temp too.
i think the valve stems i have may even work.
here are some pics, i have more stuff.
spark plug wires, ngk. for 91 civic a6 heads
