Drum Brakes I work on it for hours!
lol so I just hate hate drum brakes i had no idea what I was doing and I tried to use the book but nothing is working it took me 12hrs straight and no I am not joking hahah and now my wheel is just constantly braking. now do I have to do anything to compress the shoes again? Im so lost
http://www.hondatuningmagazine.com/tech ... index.html
Also, if you have the brake shoes adjusted too loose then your pedal will feel low. Make sure you are using the correct brake shoes as the wagons use slightly larger versions than other 88-91 civics.
