Civic wont turnover i need HELP!
Alrighty so a break down of my civic
91 Civic wagon
D15
5 speed
no engine mods
no CELs
Well i started having problems with it a month ago on a trip around town it bogged for a quick second then came back alive.. no biggie. a couple days later it did it again.. turned off for 5 seconds had some trouble starting but fired right back up.. did that alot over the next couple days.. always when the engine is hot... never a problem when its cold. So i was driving back on the freeway one night and BAM stopped... i pulled over on the side, waited a bit nothing just cranks.. so i did the usal pulled the spark plugs.. check the fuel filter.. and changed the main relay nothing! so i got it towed home were it sits now.. over the last 3 weeks i have tinkering with it trying to find a problem or solution..the first thing i did was check for spark.. nothing. so i took the dizzy apart, and noticed the rotor had some play so i put everything back together.. and tried starting it. it took 3 tries but finally started right up! so i took it for a drive 5min into the drive it started puttering and cutting out so i turned around and headed home.. i had to keep the RPM full throttle to keep it running and it died a mile away from my house so i pushed it home. This time i was pissed, so i took everything apart the dizzy.. the grounds. the valve cover off nothing everything looked alright... well put it back together and nothing the battery was dead.. so in the process of the last week i have bought new spark plugs.. new grounds... tired a new battery.. the ECU blinks once when first on so im guessing no codes?? the Fuel filter prime's and there is fuel pressure. i bought a new rotor for it and ignition coil. I installed it all and tried starting it.. it caught and fired but died within 2 secs... tried again and fired and died immediately.. so now im stumped.. im pissed and i really need my wagon to work cause i need to give my loaner car back.. PLZ if anyone has any info or help on this i would greatly appreciate it..
-John B.
91 Civic wagon
D15
5 speed
no engine mods
no CELs
-John B.
-Thanks for all the help
-John B.
