Guys I need to Dump my rear (Air ride installed)
alright guys I got my scrapper kit for my rear end and I can set the car on the ground but my Back-end will not hit the ground (aaaaahhhh) So do I just have to make some extended top hats for the rear? Cus the fronts are dumped you can't go any lower wheel is sucked all the way up and looking hot as ever but the rear is killing me.....Any advice is a + I need to get this wagon on the road
  • mr.johnsonmr.johnson Band Wagon
    make sure your camber rod/mount is not hitting the chassis.
  • Ben06Ben06 Wagonist
    ok how will I be able to tell cuz once i drop it I can't really get under it to look....And would that stop it from dropping all the way down in the reaR?
  • 91_wago91_wago Wagonist
    you need to see whats holding it up. jack the car up level on stands. then take the wheel off and jack the suspension up and see what hits.
  • JakerJaker familEE
    Take the spring/shock out before you jack up the suspension, otherwise, you're gonna lift the car off the jackstand and that's just not safe. Then if you see that the wheel goes up as far as you need it to, you'll know that it's your shock bottom out on itself.
    nope its none of those, goes down just fine, I'm guessing the bag just isn't going all the way down for safety reasons on the kit, But no biggy with me I like that I can control my height when needed.
    are you sure you using bags? or cylinders?
