Rtawd handle 350hp?
So i spent the last 2 hours trying to find info on how well the rtawd system would handle 350hp and all i could really find is that the bevel gears seem to be the weakest link. Is there anything I should do to the drive train to help it handle 350hp outside of the proper clutch and possibly rebuilding the transfer case?
Thats the best topic I know about on the forum to answer your question. If you've searched for 2 hours then you've probably found all the answers this board has. Also, you didn't need to start another thread to ask the same question you did 2 hours ago. There aren't a lot of high power RT4WD drive trains out there. The only one I know of is the EPIC EF hatch which seems to handle it just fine.
Sorry if my previous post came off like i was a dick. I was just trying to find a solid answer which i see im not going to find. I guess ill have to be the guinea pig.
anticipation
pioneer is more positive term.
When you get to 350hp start a new thread and let us know how it goes.
