Help!? Power steering!
Okay. 89 Honda civic Wagon.
I took out my power steering unit, seeing as it wasn't connected since it rolled off the lot anyways. So I also took off the lines and the pump ( i believe its the pump) back behind the motor on the frame. I got it out and everything, but when I turn the wheel left/right, fluid spills out. No big deal, it won't have power steering after the swap either...
...So my question is... Do I have to plug up where the pump was under the car? Or does the fluid that sits in the axle like tube lubricating the tie rods? Am I fine just letting the rest drain and having a small hole there?
It just crossed my mind because I've never seen a set up like that and the tie rods lead into that axle like looking pipe that runs across the bottom. I'm sorry I can't think of what the tube is called.
Please... ANY and ALL feedback is appreciated.
Thanks guys.
If pics are needed, I can take some...
Thanks guys.
steering rack
Steering rack!!! back of my mind tip of the tongue. Thank you!
Any help?
other people will need to answer this for you
The bit on the steering rack has already been effed with to remove the cooling unit. I cut the lines leaving enough to loop a hose to each end. The problem is, getting a hose to fit both ends, seeing as how they are different sizes. Is it possible to just block the holes where the fluid is supposed to be looped? Or will that create too much pressure while steering?
