Welded drive shaft?
i been lookin for a few hours and i all i end up comein acros is jakers CF one i want to mod my stock drive shaft to remove the coupler.
been done? any advise?
Anybody with knowledge on these, please fill us in.
Thanks.
Do you recall doing this worked well?
I'm wondering if this is why my 4wd doesn't work??
Essentially two holed plates (it's a lot more than two in reality) are spinning in a fluid. Normally when all wheels are turning both plates spin at the same rate.
Personally I can feel the extra drag that the 4WD gives over a 2WD civic.
When the front wheels spin the plates turn at differnt rates. The fluid in the diff forces the rear plate to start turning. Eventually the front wheels spinning stop. Either becasue they gain traction or the rear wheels catch up to the same speed.
This manual has a tear down guide for the centre diff:
http://www.hondacrx.co.uk/faq/manuals/c ... 2SH520.PDF
Welding it is an option, but it shows how you could fairly easily make a replacement for it, perhaps from some old driveshaft bits ?
P.s. you have a solid rear end, how do you think that will work out with a solid driveshaft?
I certainly wouldn't run on the road like this but people have run a welded coupler in autocross events without breakage.
Three hours of sleep is owning me right now... but all I was getting at was that the rear axles are going to bind up Badly... and good luck finding replacement rear axles for less than $300 each, lol
I know this is a dead thread but leaving the misinformation about the rear axle cost bothered me. A few weeks ago I got a new front axle at Kragen and had them look up the rears while I was there. They had them (on order) for $100 to $150. Lifetime warranty you break it they give you a new one.
Edit: Found them on Kragen's website for $134.99 http://kragen.com/ProductDetail.aspx?MfrCode=A1C&MfrPartNumber=604131&PartType=945&PTSet=A
Plan to do this on my RT soon.
Maybe not though? Since in a working center coupler it should notice a rpm difference if a set of wheels left the ground and lock up.
By welding it you are removing the time delay that the diff locks up. Thus creating a handling difference. I'm not sure one could be considered better than the other for traction/handling purposes. In the end I think it's up to the individual driver to decide which design they are more comfortable with.
If you have a working center diff, I think that it's better left alone.
I'm speaking towards road course/autox handling situations. For drag racing you may see some lower 60ft times by removing the delay in which the rear diff locks.
