+++SiWagon FYI: Tophat WARNINGS & Specs
Lately there's been a few threads on Tophat extension mods.I started this 'cuz I see a lot of mistakes.Below are some specs you'll need & things to watch for.
MAX Pipe extension OD:1 -7/8 (48mm) OD .OEM OD is a hair under 1 -7/8''.Note:You might be able to get 2"(51mm).I didn't get an exact measurement.The prob here is the chassis opening is MAYBE 2"You may need to grind the chassis opening a little to get the 2''. 2" is prefered cause then the shock boot(1 -7/8(48mm)OD GR-2 shx))may just barely fit otherwise you'll need to mod for a rubber boot.GR-2 shx bumper:1.52"(39mm).
Tophat OEM bushing Dia:1.67(42mm)A little under 1 -11/16''.
Tophat metal thickness:.1185"(almost 1/8"(3mm)).
MAX extension Height:
Front:2".Note:You maybe able to get maybe another 3/4"(19mm).Put a chuck of clay on the shx tower & close the hood to check for clearances.
Rear:1"(25mm).Note: If you want more you'll need to mod the interior panel shx cover for more room.
Ah! i'm so glad i found someone who just explained the top hat extension thing. I didn't wanna post and then have everyone yell "search....SEARCH!!!!"
yep, thats me! when you extend the tophats, does it make it ride like stock? or close to stock?
No matter what you do, if you lower the car it is not going to ride like stock. But extending the top hats will definitely increase the ride quality greatly.
nobody want that ride...well I don't but I do...
crazy smiley...
