Driveline Grinding
I've searched with no results.
When launching (I use that term loosely), I should say accelerating, I hear grinding coming from under the shifter (i would assume thats coming from the driveline). It seems to only grind when I am in first gear and that makes me think its not the driveline but it very much sounds like its coming from under my floor boards.
Thanks guys I appreciate the help
+++SiWagon TIP: Keep that Tranny.PLUS Tips & Specs
Try turning off the rear drive.If noise goes away you might have the transfer gear going out.
Sorry, noob question, MTF=Man.Transaxle fluid? And how do I turn off the rear drive?
RT4WD disengagement.
I'm pretty sure that the shift linkage doesn't got under the car. When I took off the center console thing, the shift linkage went straight through the front of the fire wall,
