Front lsd from an intrac gearbox?
I think i read somewhere that the intrac models (some of them) where fitted with optional lsd in the gearbox and rear diff. Is this true? If so can the gearbox from an intrac model with lsd just be swopped over easily to the non abs model to give the front lsd and then put a normal d series lsd in the rear diff as has been mentioned on here? I can source the intrac model in scrapyards in germany pretty easy if so.
What would be the outcome of having front and rear lsd, my screnario will be track use and maybe the odd strip now and again, so would it be beneficial for me?
Thanks :twisted:
Thanks :twisted:
No idea on the front diffs but I'm sure some on here has some experience.
Rear LSD was standard in the INTRAC model. It's not as big as people make out, it just has a longer snout. I haven't had a chance to tear one down so i don't know what will fit inside the pumpkin.
Are there any parts you guys in the US would be interested from the european models?
You can put the trans limited slip in the rear diff? is that what you were implying? if so... Drift status!! lmao.. no rele i will haha
