J32 RWD daydream
My mind was wondering on and on at work today. I had a thought, what if you took one original neat idea and put it with another?
I am sure no one here has any real answers for these questions but these are a few things that I am asking myself.
-What would keep me from using the rt wagon rear control arms?
-How could I use the Rt4wd hub that will accommodate a cv-shaft as a advantage?
http://www.honda-tech.com/showthread.php?t=2441462
Are you seriously considering buying the Epic Hatch? It's worth the asking price if you are.
yes bam-bam, yes I have.
CL = 70.6 in
Wagon = 66.1 in
That's exactly the one I mean. Too wide?
why would you want the c32 over the j32?
There is a bigger aftermarket support for the J series over the c32
Hell no that's not a bad idea. It's original AND those old school carbed rotaries made some serious NA power.
Now last night I was looking at how our trailing arm and rear crossmember sit and how much room one would have to fit a engine. I wouldn't mind using the stock rt4wd crossmember, hub and trailing arm. With that I will not have to mess with the track or alignment. The motor/tranny could for the most part be slightly off and still be ok as long as there isn't much bind on the cv-shafts. And that way if need be I could mount the motor more forward for weight distribution AND to possibly adjust to clear the rear crossmember. Custom axels will have to be made, but I would have to get custom axels anyway.
Do you mean hard to swap TO auto or FROM? I was thinking auto might be easier because of linkage. We built some mid-engine VW dragsters back in the day, and there was actually an aftermarket "turnaround" setup we bought for both of them. It was a pantograph-looking contraption that mounted to the nose of the transaxle.
...or is the tranny from the legend heavily electronic?
The MT linkage for the 6 speed would be easy because it is all cable. All you would have to do is extend the cables to "bring it around" to the back of the car. The problem with the auto swap is the wiring and the shiftmatic BS.
Click here for fab pics
