Code 1: O2 sensor? (FIXED: CLOGGED CAT)
I will delete my other thread "new clutch, new problems" when I get home as I can't do it from my phone.
So, I had my clutch replaced in my 91 rt4wd and it works wonderfully. The problem now is a loss of power when accelerating or climbing. Pedal to the metal and no acceleration when trying to pass or climb. On occasion it will accelerate but that is usually on the downhill. Downshifting doesn't help as the wagon will just go even slower. It was suggested I change my plugs and wires so I went and replaced the old ones with NGK plugs and NGK blue wires. I also went and replaced the fuel filter.
I reset the ECU, and am still getting the lack of power issue. The CEL will come on and the ECU is throwing a code 1 for the O2 sensor.
All grounds are good, nothing is unplugged. I am planning to replace the O2 sensor today but is there anything else I should be looking at? Fuel pressure regulator? Other sensors?
Thanks in advance! And yes, I did search but it was inconclusive.
James
James
With it installed I saw my code go away. I didn't see any power gains, but I did see an increase in mpg.
Yes, I got the check engine light and the ECU was throwing code 1. I bought a Bosch O2 sensor from Napa at lunch. Do I really need a special socket? My pops might have one but that sucks if I need a special one.
Not being able to rev isn't an O2 problem most likely.
I normally search honda-tech for stuff like that. Way more info there and almost everything has been covered already.
i had this issue when i did my MPFI swap, turned out i had two wires flipped at the ECU.
however, i also had this problem when my distributor went bad. but it was throwing a code 4 then.
- noticed the fuel filter was leaking. Managed to snap the smaller bolt head tightening it up. Found a bolt that fit. All is good.
- Managed to install the new O2 sensor and reset the ECU. No more code 1, and engine seemed to be running well.
- took off down the highway only to have the bogging/lack of power issues come back.
- Closer to home, we were pretty much crawling along at about 15-20 mph, letting others pass us.
- When the engine is running, in neutral and I press on the gas, it will rev fine up until 3K and then it will hesitate/bog.
- Gas mileage sucks. Had half a tank when I left work and ended up close to empty about 30 miles later.
- The shop said they didn't touch anything but the tranny. Had bad thoughts that they swapped my engine for a shitty one. Don't think they did though as I can verify with VIN numbers right since it's the original engine right?
- Haven't thrown any other codes other than Code 1.
- Could my timing have been thrown off somehow?
- Could the distributor/rotor/cap gone bad?
I'll try everyone's suggestions when I get a chance to look at the wagon. Any other ideas?
There are like 3 billion thread on various forms about d series not revving past 3k. Dizzy, grounding, injectors, and wiring are the main failures.
On a good note, he found a vacuum hose that wasn't connected to anything. I took a cell pic of it but can't seem to upload it to the comp so my description of it's whereabouts will have to do.
It's located on the passenger side of the engine bay right behind the battery and a little bit lower. It comes out straight up but we don't know where it connects to. I'll try to get a pic uploaded as soon as I can. I've even got a shop manual and I can't figure it out. I'm hoping this is the cause of my current issues with the wagon.
Thanks again!
James
Jaker,
The hose is about 1/4" ID or even a bit smaller and is no more than 5" or 6" long. There doesn't seem to be anything nearby for it to connect to though. Weird.
I'll check the O2 wiring when I get home.
Thanks!
Other than that, I think I remember hearing that the ECU can throw a code which looks like code 1 for the O2 sensor, but is actually a 1 code for a faulty ECU. Definitely double check the grounds on the thermostat, they are the main ECU/fuel system grounds. You don't happen to have a spare ECU do you?
On a side note, would a cracked OEM header or a possibly clogged cat cause my bogging and loss of power issues?
hmmm, i disagree. i had a clogged cat that busted in one day. the internals collapsed one day while i was driving down the interestate and soon as i exitted i couldnt go faster then 45. eventually one this same trip home (20 miles) i could go past 25. it was bogging like CRAZY.
progress, this could be your problem.
If my header is cracked, does it need to be welded? Or can I just get another OEM header from any other D series engine?
Started the wagon for a few minutes since it wss pretty late and no more bogging or hesitation at 2500 rpms! Hopefully we've solved my engine issues and I can get my wagon back on the road.
Thanks for everyone's help!
glad to see the problem is solved. almost
