master cylinder
Hi
Does anyone have experience replacing the master cylinder? the lines that go into our 89 wagon 's master cylinder point downward (like an upside down letter "U"), thus rendering it impossible to fill them with fluid before screwing onto the master cylinder. How do you remove the air?
Thanks
Lorianne
Thanks
Lorianne
buy a new MC from your local Honda dealer..preferably a 15/16ths one..a 91 EX has a 15/16ths cuz that's the one i put in.
you should unscrew all the hardlines with an open flare nut wrench and pull out the MC from the booster.
take the cup out of the top and get rid of what's left in there and pour in some fresh fluid.
then pump the piston with your hand so it will squirt out some of that new fluid you just put in..and that will remove any air.
got it?
