Help the bolt in my lower arm is ceased to the bushing
I am in the process of doing my engine swap and have just about everything off the old engine and got to pulling the axles. Passengers side came free not too bad but I'm stuck on the drivers side. I noticed when I went to remove the fork from the lower arm that the bottom bolt was longer and had a smaller head like somebody must have replaced it over the last 21 years with whatever they had that was close. Well I got the wrenches on it and next thing I knew I had the head of it sheared off and the bolt hadn't moved at all. I eventually got it to spin...so I thought and started to try and hammer it out with no luck. Went and got my gear puller and started trying to force it out that way. After lots of struggling and confusion I figured out that the bushing is sliding out of the arm and the bolt is very solidly stuck to it.
So any ideas on how to get the whole mess out? No matter what I try and do I end up just pushing the bushing out and spreading the fork apart.
I had to do this recently on my EP3 when I did a suspension change. Worked like a champ.
