Toe adjustment on a lowered wagon
i read something where some one said you will need a toe kit when you lower a wagon? ive owned plenty of lowered civics and never needed a toe kit to get it to align right. is the suspension of a wagon different? i know the rear shocks are.
the rear compensator arms are attached to the rear trailing arms and the chassis. the bolt on the chassis is the one that you loosen up to move the toe in or out.
hope this helps
That is where toe adjustment kits come in.
Just saying that the option is there if you need more adjustment.
Not sure on the drop. it's pretty low.
The front doesn't need toe adjusters...that's what the tie rods are for.
The rear may or may not need them. Check with your alignment tech. You may not need them at all.
i work in a tire shop and do alignments frequently, i just never have come to this problem.
You shouldn't need more adjustment unless you have some bent shit in your suspension!!
LOL! You're funny.
Nothing's bent. It's quite minty as a matter of fact. I am just stating what the computer and the alignment tech said. But nonetheless, I'll be sure to go back there and tell him that you said I shouldn't need anymore adjustment and that I obviously have some bent shit in my suspension. Either that or he's not qualified to do his job and his equipment is in need of calibration. /sarcasm :roll:
