Can I tap this hole deeper?
Hey everybody,
I am reusing the D16A6 from my totaled wagon in my new hatchback. The only problem is that the driver's side engine mount tore out of the block in the crash. I have already re-tapped the upper bolt hole in the block one size larger (same thread pitch) to M12x1.25 with a forming tap, and there are plenty of threads available. My problem is that the lower bolt tore out diagonally and there isn't but about 2 threads left.
Does anybody have any idea if I can get away with drilling this hole deeper in order to tap more threads?
I'm already working on fabricating an engine mount "extension" that will be able to bolt to the front of the block, but I reaaaally want to try and get a bolt torqued down in both of the stock mount holes also.
Any input on what else I could do to try and strengthen this connection? I'm going to mock up the bracket I want to fabricate with cardboard today, I'll get some pictures.
Thanks Jaker!
Yes I know exactly what you're talking about. Here it is:
Only it has one bolt hole in the block and one bolt hole in the mount. The piece I'm fabbing is meant to weld onto that bracket and bolt lower in the front of the block to effectively make the bracket into a triangle.
And yes I double checked the front and rear mounts, they are fine, and I am going to continue to use my poly inserts as well.
thanks for the input guys!
That same bracket is on the D16A6 as well.
I'll keep that in mind, but I'm super broke. If I had any extra money I would just go ahead and buy another A6 block from someone.
Here is what I'm working on for the new mount bracket. Looks like I need to drill out another piece of plate so that I can get the edge of it and the bracket above it more parallel before I weld it.
And the machine shop may be cheaper than you think...
2wd automatic ones do.
I've seen another B20 block which was as bad as yours but he was fitting to a mk3 civic which front mounts from the head so got the block dirt cheap.
I like your engineeering around the solution but for me, I'd definately have had it welded and retapped.
I think you want to put a vertical brace on the underside of the link from your plate to the rubber mount, so the link would look like a T cross sectioned.
I cut a piece off the end of the plate today and sprayed it with some rustoleum, then dropped the engine in. No problems with getting the mounts all bolted in, everything went right together and the engine appears to be sitting normally.
And here's me hoping this shit is gunna work!
Got the engine in....
And just for kicks here are some triple trees my roommate made in the CNC mill for a guy in Southport, NC building a high speed bike. Pure metal sex!
I found a power steering bracket in one of my spare parts bins. Parts hoarding ftw! So now I see what you're talking about! I guess I should have just used this in the first place to make it all that much easier, but it was kind of fun to make that bracket. I'm just going to run what I've got on there right now and see how it does. I put a really thick coat of spray paint over the weld so hopefully if it flexes at all the paint will crack and I'll be able to tell. We'll see what happens! I think in the long run it would be a better idea to run the PS bracket because the holes that the mount bolts go through are much closer to the diameter of the bolts. On my bracket I had to use the only big drill bit I could find in the drill press to make the holes, so they are a bit bigger than the bolts. But with four big bolts in there it shouldn't be a problem...... anyways ramble ramble ramble......
I ask myself this every time i get ready to bang my fiance.
you romantic devil, you...
I can't lie, the thread title has made me grin a few times too.
