Trying to quit smoking
I've done some searching, and now I'm ready for opinions. I can't tell where all oil/coolant is totally leaking from yet. I just recently scrubbed my long block. And oil seems to specifically be coming from distributor and something on the other side (head gasket area anyway). Not sure if it's coming from P/S or cam seal or head gasket....Nothing in the middle. Except for my valve cover gasket. That is leaking across the head/exhaust manifold. One of the plugs also had a fair amount of oil when I pulled it.
When the car warms up and I pull away in first- I get a big puff of blue smoke.
Naturally I want to rid this. The car runs really really well. It's quiet and strong. I'm leaning towards doing all of the head related gaskets (and oil pan) here soon. But I'm getting these whispers of valve guide seals in my ears. And I'm wondering if I should do these before I pull the head? Or should I just say 'fuck it' and do them all regardless?
I'm not afraid to say I've never been inside a motor before. So I'm just looking for some encouragement/wisdom from our more experienced members. I've read a couple different manuals, a couple of different times. And I'm confident this won't be hard at all. Then maybe this is something that can be quick-linked in the future with my results and pictures.
Thanks in advance!
Thanks in advance!
Valve stem seals may help with your problem, and they can be done with the head on the car, but NOT by a novice. It's a tricky procedure at best.
This is the sort of info I was looking for. Thanks bam!
I'm kinda leaning towards just driving it until it doesn't run anymore. Then just go straight to a Z6 longblock.
I basically don't want to get all deep, and not solve my problem.
