Swapping a 1988 engine into a 1990 wagon RT4WD
What parts are the 1988 engines missing that the 1990's have? I have two extra wires and I know that they go to something. I swapped an 88' RT4WD engine with PGF-I intake into my 1990 RT4WD shell and found that the drivers side harness's are different. because of this I'm repining the 88' engine harness into a 90' one. The only problem is that the 88' engine harness only has 6 wires and the 90' has 8 wires. The two extra are black/yellow and blue. Can anyone tell me what these wires are for and if I need to run them?
if your civic is the 6speed then you can get the engine harness off the hatch or crx si 89-91 and should be plug n play.
