Hoisting out engine
I'm getting ready to pull the d15 out of the hatch to swap my d16a6 in. I have done this once before just a few months ago but I have some questions.
I've seen a lot of people saying it is easier to just pull the engine and trans together at the same time, but last time I took off the trans before I pulled the engine. My quesions are: do you all really think it is easier to pull the engine and tranny together? And how should I position the chain on the engine if I pull them at the same time?
When I pulled just the engine out I had the chain bolted to an exhaust mani stud and the wrapped around through the intake runners on the other side. I guess it would work for me to do that again and I can just expect the thing to droop down on the tranny side because of the weight?
Any input would be much appreciated!
My video on how to remove a motor/tranny - but I do it through the bottom - don't have to tilt the motor or anything!!!
I bought a leveler from Harbor Freight. I think it was like $40. Worth skipping the headache IMO.
If it's 2wd, it's easy enough to pull it through the top. Never again will I waste my time pulling a 4wd motor/tranny out through the top!
It that a supercharged ZC on the shelf there to the left?
lol have you read his thread? You should...
As long as you're considering where you place the hook on the chain, it will balance pretty well without a leveler. There's a lot more weight centered on the longblock, enough that you don't need to worry connecting a chain to the tranny.
Take your time. And it should be easy assuming everything is disconnected.
rage- you're crazy haha
be careful if you leave the wire harness on there (I leave it on, but I'm careful) so you don't smash a connector... especially a main connector.
I usually leave the 2wd Shift linkage on and just navigate it out. OMG the 4wd is so nice with the cable linkage!!
Looks like you bolted it correct in your picture. There is threading near the number 1 intake and a bolt on the transmission that I use to lift it out. Never failed. I like the auto-levelers, definitely makes life easier.
I personally think it's easier to pull it out from the top, but some people disagree.
I had great success pulling a motor without the tranny. I was very pleased with this because it is more of a pain in the rear to deal with all the things associated with the tranny if it does not NEED to come out. All the timing components, engine mount bracket and alternator need to come off so the engine has room to move away from the tranny. The clearance from the flywheel to the inboard CV Housing is very tight. I turned the axle so the raised part of the housing is out of the way of the flywheel for re-installation of the motor. ( I had trouble installing 'til I figured this out. )
The second time I did this on a '95 Civic, removal and installation of the motor was very smooth.
I know this is a late comment for this thread though I hope this info helps someone in the future!
Thank you for all the information on this forum!
1991 Civic Wagon 2WD
That alone usually makes me take them out together.
