4wd won't re-engage
I searched with no luck.
It was easy to switch it over to disengage the 4wd for towing. Now I'm trying to re-engage it, and about half way it hits something. Almost like the click when you're putting it into gear. Is there a trick or what the hell am I missing? Car is in the air with all four off the ground, and in neutral.
Maybe I just need to be more forceful. I just don't want to be too rough and regret it.
Thanks in advance!
Thanks in advance!
Edited for minor correction in terminology
Thanks man. Gonna chow then give it a shot. I'll check back in a bit.
Then I spun the front driver wheel just a little. 4wd lever slid right back in with no problem.
Thanks for the help guys!
