What suspension setup is better for the Wago?
Been having a hard time deciding which suspension set up I should go with for my RT4WD wagon? What do you guys think i should go with: G.C. with Koni Yellows, skunk2 shocks and springs, or skunk2 coil-overs? If any one has any other suggestions please reply or post sum rides with the suspension setup. . .
Do you want to be low slow and all for show? Or are you after something for the track? Maybe a mix.
I personally run Koni Yellows with generic lowering springs and find them perfect for daily driving, once I add extended tophats the ride will be better again. Whereas in my other car I run Tein Coilovers with 14kg/10kg spring rates and I find that a bit harsh for daily use
