Hello from France (Europe) MK1 [AR65] 1987
Hello,
I have a Shuttle 4wd with 200 000kms (aprox. 125000miles), his birthday is December 1st for 1987.
You can see below the monster:
Thanks for your comment.
Nicolas
Nicolas
How long have you had her?
thanks for joining HCW...
Sorry, that was most of the French je parlez.
I have a lot of work, but I suppose that I can use it before the next winter ...
- http://www.energysuspensionparts.com/pr ... rod=DIYMMI
- air filter
- oil filter
- 4 sparks
- valve cover gasket
- water pump
- timing belt kit
- used left mirror
That's all for the moment ...
Have you ever heard of the band Gorod? They're an awesome metal band from Bordeaux
welcome here, there is little work, but the beast is rare,it's worth 8)
then good luck
I want to know what is necessary for change carburator system to injection, what is the list of material? (My engine code is EW2)
(information: is it expensive to buy the injection with accessory in US?)
Thanks
Nicolas
I recovered a little back door.
Some pictures of the engine compartment:
Can someone just tell me if anything is missing mounting bolts on the header above? Thank you
the rear wheel arches back
So that's the gear, a little disappointed because it has suffered since it sleeps outside, rear tires
slashed (wheels replaced by others to roll)
rust underbody, the rear shock at the rear axle ... otherwise it is quite
clean inside, better than mine ... but here are the pictures:
It is very dusty, because I made a small discovery, behind the clock,
there was plenty of dust and at the same time I looked at the sticker
insurance that includes "2004"
We see in this picture that Neiman has jumped, it's me, otherwise I could not turn
the wheel because there is no key.
Here we can see that the rear took quite a blow, to say, the panhard bar
can not really do its job, and the right shock absorber to the rod is twisted.
It seems she fell, where and how, I do not know.
You really have to be crazy to do this trip for it, besides, I asked myself why I did when I got home.
Anyway, it will end the demolition after taking everything that interests me.
Unless someone is interested to get the cash (I give)
Depending on the time that I have, I'll see if I get the box, the tree and the bridge
otherwise I will leave with the cash, it can always interested to somebody
mounting on a 4x4 AF or AH
but I'll get the front torsion bar and fixings
I noticed that both models are different, the black interior mirror, the rear seat cushions separate box
between an ashtray and gear lever, the seat upholstery with different front and rear headrests on 1987
whereas in 1986 as pictures retro interior is white and also supports for the rear deck.
It just may be options
So I start looking for docs on this vehicle or photos.
